• Version 7.00 battery drain?
    Hello,
    Yesterday I rode for 7 hours and when got home battery was less than 30%. Today a 3h ride the battery went from 98% to 65%. That’s 10% average per hour.
    previously with the same sensors and livetrack I was getting 5-6% battery drain in…
  • RE: Battery Drain
    Update 13/10
    I received a somewhat automatic response from garmin support with instructions on how to maximize battery life and a procedure to test the battery life during an activity vs the declared battery life on the specifications. I sent a response…
  • Battery drain on 8.18
    Hi,
    Suddenly (in 3 hours) estimated battery life dropped from 7 days to 2 days.
    I connected watch to charger. After fully charged it again dropped from max (10 days) to 6 days in 3 hours.
    I'm on 8.18 software. I'm using Garmin provided watch face and…
  • RE: Battery drain and varia light
    Thank you, that's works. Remaining only battery drain issue.
  • RE: 9.17 battery drain remains
    No AOD, no SPO2.  ZERO GPS activities during this time.  I've changed nothing. The battery drain started with the last update and this one isn't any better.
  • RE: 13.22 battery drain nearly doubled
    Interesting. With 11.28 I did not notice any changes with battery drain.
  • Battery drains fast (v7.80)
    Since a few weeks the battery of my Vivoactive 4S is draining much faster than it used to do. Now overnight (about 8 hours), the battery went from 100% to about 80%. I didn't change anything on the watch. Also, after a factory reset with removing all…
  • RE: Fenix 7XSS battery drain?
    Hi,
    It doesn't seem to be normal that Battery drain you have experienced. I will recommend you the typical reset of the watch and review your current watch settings: Pulse OX on, Backlight On, Brightness, HRV log on, ... Flashlight drains battery as well…
  • forerunner 945 fast battery drain
    I have several garmins and one of them is a forerunner 945. They have a problem with fast battery drain. perhaps there is a solution? who will tell? Pray
