Garmin Forums
Garmin Forums
  • Site
  • User
  • Site
  • Search
  • User
  • Apps & Software
  • Outdoor Recreation
  • Sports & Fitness
  • Pilots
  • Developer
  • Beta Program
  • German Forum
  • More
  • Cancel
  • RE: Insane Battery drain Epix pro2 47mm
    SPEKTR
    SPEKTR
    With 21.15 i also noticed higher battery drain on my enduro 2. Something must be draining the battery, phone connection is off, wifi is also off, and my hour consumption is like 0.25%/h, which is in idle mode a lot higher than before.
    • 2 months ago
    • Fenix 7/Fenix 7 Pro - Epix 2/Epix 2 Pro - Enduro 2 - Quatix 7 - Marq 2
    • Community Discussion
  • GCM iPhone battery drain, Epix 9.28
    Tomasz
    Tomasz
    Do GCM on iOS drain the battery like crazy while running in the background? Tonight it drained more than 20% of the battery on my iPhone. I should add that GCM is always running in the background, but before that there were no problems.
    • over 2 years ago
  • Battery drains twice as fast epix gen2 11.22 beta
    524ea5e4941f4337820e64cf86920013
    Hello,
    since the update to beta 11.22 my battery drains twice as fast.
    I’ve tried to reset it but didn’t work.
    anyone with similar problem?
    Barrie
    • over 2 years ago
    • Fenix 7 Family - Public Beta Reports
    • Public Beta 11.xx
  • Serious Battery Drain on 13.09. Epix 2.
    NemoSandman
    NemoSandman
    Hello,
    All in the title.
    I have Even tried to use Battery Saver and of course I have soft reset the Epix.
    But with no AOD I got the same stamina as WITH AOD.
    SO there is a problem.
    • over 2 years ago
    • Public Beta 13.xx
  • 9.32 Epix 2 – No change in catastrophic battery drain
    BTX
    BTX
    For anyone interested:
    The update to 9.32 has not changed the massive battery drain. You can still see the percentages decreasing.
    @Garmin: Please see that you restore the battery behaviour from 9.28.
    Or give affected users some way to downgrade to this…
    • over 2 years ago
    • Public Beta 9.xx
  • RE: Battery drain epix Pro 2 gen 51mm 17.23
    ronitau
    ronitau
    Hello, Mine is draining battery at a rapid pace also... same version, and it is started few days ago also...
    It started after I synced the watch to the computer. hard rest, default settings, nothing worked...
    • over 1 year ago
    • Wearables
    • Epix (Gen 2) Series
  • Battery drain epix Pro 2 gen 51mm 17.23
    Eduardo PT
    Eduardo PT
    Ontem depois de uma corrida rápida ainda estava com cerca de 24 % de bateria e estimativa de 5 dias, esta noite foi abaixo completamente descarregou a bateria toda enquanto dormia... ontem a noite apenas usei cronometro e mudei u widget de coach para…
    • over 1 year ago
    • Wearables
  • Garmin employee stated that all Fenix and Epix series watches have battery drain issue
    6591133
    6591133
    On the phone today to Garmin about the 19.41 disaster. No confirmation that 20.16 will fix or even address the battery drain issue. Since I get a day and a half out of my watch - it's essentially unusable. Customer support offered to talk to management…
    • 5 months ago
    • Wearables
  • RE: Rapid battery drain - Software update 14.31
    seilogramp
    seilogramp
    • v14.31 - Epix 2 Battery Fast Drain after Updating - Epix (Gen 2) - Wearables - Garmin Forums
    • FENIX 7 SOFTWARE UPDATE 14.31 BATTERY DRAIN - fēnix 7 series - Wearables - Garmin Forums
    • over 1 year ago
  • Battery Draining Epix Pro 51mm Iphone 14 pro (iOS 17)
    IH_Patriota
    IH_Patriota
    As I noticed in 14.68 release the watch has a big draining problem in standby/watch mode due to instable connectione with iPhone 14 pro.
    1h20' running activity (paired with external cardio Polar) earns about 1,5%-2% battery (1,38%/ - hour), standby…
    • over 1 year ago
    • Public Beta 15.xx
Copyright © 1996-2023 Garmin Ltd. or its subsidiaries
  • Site Map
  • Terms of Use
  • Privacy
  • Security
