• Firmware 17.10 strong battery drain
    Firmware 17.10 strong battery drain also after hard reset
  • RE: FW 12.1 battery drain
    Reverted back to FW 11.20, no more battery drain ...
  • RE: Battery drain when off
    Same battery drain here with my Garmin Edge 530.
  • 9.20 - battery drain
    I am experiencing crazy battery drain. Running 9.20, but I am 90% sure it started with Garmin outage.
    Tried power cycling watch, even full master reset with data wipe, still same.
    Loosing 3bars in 2 days just by smartwatch use. Compared to what I was…
  • RE: 26.95 battery drain
    My watch drains its battery during a day without activity, the last 50% is drained in a couple of hours.
    Contact between watch and phone is cut when the distance becomes more than about 2 meters with clear visibility.
    Could this have something to do with…
  • Firmware 12.80 - Battery Drain
    Anyone else experiencing battery drain after updating? My unit seems to turn itself on during day and not turn off.
    Any one got ideas on how to fix?
  • RE: Overnight battery drains
    50% battery drain overnight is indeed far from normal. I assume you tried a factory reset and just only using the standard watchfaces, widgets, apps and data fields already?
  • RE: Huge battery drain 9.19
    same issue here for me, massive battery drain after 9.19.
  • Battery drain
    Since last beta my watch start draining a lot of battery. 2 days between charges Fênix 8 amoled 47 mm version
  • RE: Battery Drain
    I am also facing similar problem.  After the 23.10 update, my Fenix 6 battery is draining fast and it depletes within a day. Anyone else has the similar problem.
