Is there any issues with draining the battery down to 1-5% before recharging? Is there a preferred % to recharge?
Since I got the beta update, my watch has a battery drain of around 20% in the last 15hrs.
13.21B the watch consumes a lot of battery doing nothing.
During various firmwares I never experienced battery drain.
I already reset the watch, as others stated about 4 days when before it was like 10
https://forums.garmin.com/sports-fitness/running-multisport…
Battery drains from 100-0% in about 24 hours, no change in rate with activities or battery saver mode, since around 13.15.
With 18.21 my battery drains 25% per day, with the same configuration, previously with 17.x the battery drained 12% per day.
My husband's Instinct is having the same issue. day 1 seems to be ok, but day 2 and the battery drains completely. He could go 2 weeks before. I did a reset as instructed here with zero results. I'm unsure what to do but it's very frustrating.…
Check that the watch doesn't Broadcast your HR: Scroll to Heart Rate widget, press screen until menu shows up, select "Heart Rate Settings", set "Broadcast in activity" to off(grey) and "Broadcast" to off(grey). That made a difference on battery drain…
I had battery drain on 18.14, after disabling Incident detection problem was solved. On 18.15 is still ok. - 0.18%/H.
Hello, my Vivoactive 3 battery drains so fast. When GPS is on my battery is discharging 27% per hour. Are you experiencing the same?
