• Battery Drain
    I have the Epix Pro Gen2 Sapphire 47mm and running version 18.12 of the beta software.
    I have noticed since this update that the battery has been draining quicker than it has been prior to the update.
    I completely charged it on Monday the 26th in the…
  • RE: Battery Drain Problem
    Same thing started happening to me last week.
    And did you try what was suggested in this thread: Troubleshooting guide for high battery drain ?
  • RE: Battery Drain
    Note change in beta FW 13.15 - " Improves the syncing of settings between the device and Garmin Connect Mobile." . I expect this will address the battery drain issue for many, including me. Will try and post results here.
  • RE: Battery drain
    Hello, I am sorry to hear you are having trouble with this. For the concern with the battery drain, I would love to help investigate this further. For this, I will reach out to directly via Private Message.
  • RE: Battery draining
    Hello
    I am sorry to hear you are having trouble with the battery draining too quickly on the watch.
    Our engineers are still investigating battery drain concerns associated with the Fenix 8. They would like to point out many things that are expected…
  • Strange battery drain.
    Got a strange battery drain today.
    After a short morning run with music I realized after approximately 2 hours that my battery had drained 40-50%.
    I turned off the watch. After that I hardly could turn it on. Don't know how I did. Think I held some buttons…
  • (BUG) 15.77 large battery drain
    NEW bug on 15.77, massive battery drain. Probably around 5X battery consumption
  • RE: Battery drain overnight
    Maybe the new 6.30 software fixes the battery drain if it is related to backlight.
  • Firmware 12.90 Battery Drain
    v12.90 has not solved the battery drain reintroduced with v12.80.
    Did a 1h ride today and battery went from 100% to 70%.
    Should be easy for Garmin to sort out given they eventually sorted the previous battery drain problem, so they should know what is causing…
  • Battery drain while sleeping.
    It’s a good news, I did notice that while sleeping the battery drain is Significantly lesser. I have every sensor on while sleeping, including the oxy meter. Before the software update the battery drain was approximately 5%  it is between two and…
