• Battery drain after update
    You should be aware that in the VA3, after the upgrade in the software the battery is lasting only a few hours.
    Thousands of owners have already tried all the options ( Factory reset, No watchfaces or any other CIQ apps, discharge and full charge cycles…
  • Battery drain is massive!
    I have the Garmin Fenix 8 Solar Sapphire 51 mm. Supposedly, the catalog states that the battery should last 30+ days in smartwatch mode.
    The watch barely lasts 7 days with 1.5 hours of cycling per day, where I use the satellites. Other than that,…
  • Battery drain Fenix 6
    Recently I upgraded my iPhone to latest iOS version and now my Fenix 6 battery only lasts a few days. It took I while before I figured it out is was the phone connection and maybe related to the new iOS version.
    I switched off the phone connection from…
  • Fenix 5 - Firmware 19.10.0.0 - Battery Drain + Calendar
    I have firmware 19.10.0.0 instaled on my garmin fenix 5 since 27/03/2020 and battery use, was fine.
    2 weeks ago i started to use marathon trainning in exercices, so they (the exercices) migrated to calendar and to my fenix everytime i sinc.
    Can the battery…
  • Battery drain 10% overnight -Fenix 7x sapphire solar
    Fenix 7x Sapphire Solar 2.5y old.
    Battery drain increased lately. 10% overnight in sleep mode. Roughly 1% per hour.
    Software 17.28.
    Wifi off.
    Watch face with no data.
    Did reset to default settings.
  • RE: Battery drain problem when HR sensor turn on
    I changed the battery and still, I have a problem with battery drain... it is not a battery problem, unfortunately...
  • Battery drain on vivoactive4
    I went to sleep with 65% yesterday and woke up to 34% this morning, with 6 hours of sleep.
    And today, I charged it like 2 hours ago and already at 92%?! I bought this yesterday! Wherea the 8 days battery life?
    I turned off everything yesterday. How can…
  • RE: fenix 5 25.0 update battery drain issue
    Did you find a fix? I got this update a week back and since then I notice a hug battery drain. Tried restarting the device, soft recent and a hard reset. No luck :(
  • RE: 14.15 Battery draining issues 955
    I'm a new owner of a 955 Solar and every morning I notice a sudden drop in battery...Watch is brand new only 10 days old, bought from a local Garmin dealer - Cyprus...I have a morning report with only 2 options - watch and calendar, but that's hardly…
  • High Battery Drain last few months
    When I got my 965 almost a year ago I was fine with the battery drain, getting about 4 days of use with a relatively high amount of GPS activity (about 1-1.5 hours per day on average).
    Something however happened with the previous FW update and I have…
