• Battery Drained Overnight (18.11B)
    I woke up to find my Fenix 7X SS was powered off. When I turned it on - it has 0% battery. It was charged recently. I typically don't let it get below 45% before I throw it on the charger while I'm showering. This is on version 18.11 beta.
  • RE: Fenix 7 - Battery drain with 16.20
    I'm seeing the same thing on my Epix 2, I've lost 17% in less than 24 hours (with activity), normally 8-9% every 24 hours (with activity).
  • Significant battery drain, Fenix 7x Pro 17.10
    Loaded this Friday night before a Saturday 5k and all appeared well.  I had ~75% battery at that point.
    I'm now at 56% this morning, which is much greater loss given one relatively short activity during the last two days than I expected.  Its not ridiculous…
  • battery drains every night
    the last few days I wake up with a dead battery every morning. After charging it, the watch is functional. At disconnecting i get the message that an update is installed. Antenna + software is updated. Every time.
    I have tried the hard reset, but it does…
  • Battery drain Fenix 6x
    Hi all,
    I also experience issue with the battery of my Fenix 6 and I have read through a lot of the comments on this topics. We all try to find a solution for the issue but the fact is that Garmin should find a solution, not the customers. We all paid…
  • Battery Drain 22 hours
    My Vioactive 3 is 9 months old. Upto four days ago, I averaged 4-5 days of battery use before it required charging. Now I'm lucky to get 22 hours.
    I have all low power consumption processes, i.e. 10% backlight, limited GPS and restricted Bluetooth…
  • Battery drain after update
    You should be aware that in the VA3, after the upgrade in the software the battery is lasting only a few hours.
    Thousands of owners have already tried all the options ( Factory reset, No watchfaces or any other CIQ apps, discharge and full charge cycles…
