Garmin Forums
Garmin Forums
  • Site
  • User
  • Site
  • Search
  • User
  • Apps & Software
  • Outdoor Recreation
  • Sports & Fitness
  • Pilots
  • Developer
  • Beta Program
  • German Forum
  • More
  • Cancel
  • RE: Battery drain after activity - possible answer
    StefanWilliams
    StefanWilliams
    I think the original battery drain issues were addressed in a firmware update sometime last year, at least for me that was the case.  No doubt you are seeing some issue, but I don't think it's the same (people were experiencing this with minimum features…
    • over 5 years ago
    • Outdoor Recreation Archive
    • fēnix 5 Plus Series
  • RE: Solution to battery drain? (New issue for me)
    bluefish
    bluefish
    forums.garmin.com/.../bug-in-13-10---battery-drain-on-fenix-6s-pro
    • over 4 years ago
    • Wearables
    • fēnix 6 Series
  • RE: Battery drain 19.05
    9357303
    9357303
    Hello,
    Check for Background Apps: Sometimes, apps running in the background can consume a lot of battery. Go to your phone's settings and check which apps are using the most battery and consider restricting their background activity.
    Adjust Screen…
    • 8 months ago
    • Health & Wellness
    • Venu 2
  • High drain battery after last update
    Rafael R
    Rafael R
    After the last update (20.40) my mk2i has been high battery drain. I did the factory reset, but the the problem still continue.
    • over 1 year ago
    • Wearables
    • Descent Mk2 Series
  • RE: Edge 530 battery drained overnight, sticky buttons
    mjohannisson
    mjohannisson
    My battery drained when powered off too, contacted Garmin support and they said i should send it back,i did and they sent a new one to me.
    • over 6 years ago
    • Cycling
    • Edge 530
  • Heart rate strap draining battery
    thetechman29
    thetechman29
    My watch tries to constantly connect to my hr strap so I have to manually turn it off so it stops searching. Please fix because drains my watch battery and especially drains my hr strap battery
    • over 1 year ago
    • Fenix 7 Family - Public Beta Reports
    • Public Beta 17.xx
  • RE: Massive Battery Drain with Inreach Mini Connection
    mcalista
    mcalista
    2023574 said:
    Only thing stopping the battery drain is turn off the watch and on again...
    As a less drastic solution, perhaps just turn the InReach connection off in the Sensors and Accessories menu unless you are actually using the InReach? You can turn…
    • over 4 years ago
    • Running/Multisport
    • Forerunner 945
  • battery drain workaround idea and observations
    Tcornall
    Tcornall
    I wondered about the reported large battery drain still present with v19.41 on Fenix 7. I looked at the battery chart and it appeared quite normal. Then I started an activity with GPS. After an hour I stopped the activity, but the battery discharge was…
    • 8 months ago
    • Wearables
    • fēnix 7 Series
  • My battery drain solution
    Jarkou
    Jarkou
    Factory reset, battery holds.
    • over 1 year ago
    • vivoactive 5 Series
    • Community Discussion
  • Draining battery
    ebd4def8bb8c4854ba4d00c4b51b2db7
    since updating to 17.10x, the battery dropped from 10 days to 1 day in less than 24 hours
    • over 1 year ago
    • Public Beta 17.xx
Copyright © 1996-2023 Garmin Ltd. or its subsidiaries
  • Site Map
  • Terms of Use
  • Privacy
  • Security
