When I enter a flight plan in the GPS 175 and select/load an approach, the approach is loaded after the destination airport. How do I make the approach appear before the destination?
Hello,
When you load an approach, you will want to activate it in order for it to appear before the destination airport. If you load the approach then it will appear after the destination airport. I hope this helps!
I finally had a chance to try this yesterday. I had entered a simple flight plan, E14-KLAM. When I activated the approach to KLAM, the flight plan disappeared and all that showed was the the approach waypoints, no destination. And perhaps because E14 is not far from KLAM, the 175 took me direct to the FAF, not the IAF as usual.
