Dear Technical Support Team,
I would like to request your assistance and technical guidance regarding a Cessna 162 Skycatcher aircraft.
The aircraft was originally equipped with two GDU 375 units, which were replaced with two G3X displays due to equipment malfunctions. Additionally, the GSU 73 and the configuration modules were also replaced.
The installation and system configuration were completed, and all equipment and functions are operating correctly, except for the Engine Oil Temperature and Oil Pressure indications. These two sensors are not providing any readings on the G3X displays.
Despite performing several troubleshooting procedures and configuration checks, I have been unable to obtain valid readings from either sensor.
I would appreciate any technical guidance or recommendations regarding additional troubleshooting steps, configuration settings, or possible compatibility issues that could help identify the cause of this problem.
Thank you in advance for your support. I look forward to your recommendations.
Best regards,
