Bug: App crash when selecting altitude and departure is outside forecast range
Not sure if this is the best place to report bugs. If not, the proper place is not easily found.
The Garmin Pilot app crashes when attempting to select an altitude in a flight where the departure date is seemingly outside the available wind forecast range.
To reproduce: enter flight plan route; in details tab, select a departure date some days in the future (4 in my case), then attempt to change altitude. The app crashes when the altitude field is tapped.
Garmin Pilot v25.7.1 on Android.
  • Hello! Thank you for being patient, if this issue is still present, please ensure your device is on its latest operating system version and Garmin Pilot is running version 25.10.0 (iOS) or 25.11 (Android). If the problem persists after updating to these versions, please call 866-739-5687 for help from Aviation Product Support so we may troubleshoot more efficiently and create a ticket if necessary.
  • The issue looks to be resolved, thanks!
  • I have a similar issue on 25.12.3
    When I touch on an airport on the map, Garmin Pilot crashes and the iPad has to force close Garmin Pilot.
    If you use split screen and assign the airport tab to it, you can never use split screen without it crashing.
    This just started with 25.12.3 and I WISH I could downgrade to 25.12.2 where my older iPad would still be fine.
    The solution of forcing me to buy a $1500 new iPad to get iOS 18 is unacceptable.
    My old android tablet running Garmin Pilot 25.7.1 now works better than
    my iPad.
    My iPad runs iOS 17 and can NOT be upgraded to 18.
  • Today I AGAIN remove Garmin Pilot and re-installed it.  This is the third time I've done that.
    Today that bug is gone.  It must have been fixedd since the last time I re-install Garmin Pilot.
    The great news is that I can continue to use my iOS V17 iPad that I love.  I do not plan on getting a new iPad.
