Hi
Anyone else noticed the numbers on the inner bezel on the MARQ Captain (Gen 2), makes no sense. No help in manuel either.
They goes like this: 10 - 14 - 16 - 15 - 17 - 19 - 25 - 21 - 19 - 17 - I - 09
@Garmin?
Hi
@Garmin?
If these instructions given do not make sense, you are welcome to send me a Private Message and I will be happy to learn more for you but it will take time.
When the MARQ (Gen 2) Captain was released,…
The inner display numbers represent the wind in knots for sailing only. When the color turns from white to turquoise, it represents more ideal conditions to sail. The wind speed for ideal sailing is a setting…
Update: the colors of the numbers on the inside bezel do make sense: when you go into this watch face settings, you can adjust preferred wind speed. The colors pick up this setting. So if you set it to…
That’s how it’s working. It’s a great feature. Suggestion, I’m 50km away from the ocean/marina. Would be great if I could have the dial representing the wind speed at the coast, not my home.
how frequently is this information updated?
In the menu of the Garmin Connect app go to Settings » User Settings » Weather Location and enable the option Use Fixed Location, where you enter a location close to the coast (preferably near an airport, because the majority of Garmin's weather data comes from airport meteo stations).
Every 20 minutes at most, as long as the Location services on the phone are enabled, and there is a data link.
See also the article Questions About the Weather Widget on a Garmin Device | Garmin Customer Support
Thx for helping out trux! Much appreciated.
