Hey there!
As my old Suunto Ambit Peak 3 is slowly going into retirement, I am looking into the Garmin Instinct 2X/3 Solar as a replacement.
I kind of like the monochromatic display, and it looks like the Instinct could keep up with the battery life of the Ambit Peak.
My use cases are mostly hikes and long(er) distance hikes. Going through the specs, the Instinct looks really good; however, I have some more specific questions about some of the features, especially things that I do not like in the Ambit Peak.
So maybe some Instinct owners could give some insight on that:
Navigation, Route & POIs
One thing that bothered me with the Ambit Peak is that you could load a GPX and navigate it OR you could navigate to a POI. But somehow it was not able to navigate a route and at the same time show saved POIs. Is this possible with the Instinct? Background is: On longer hikes I would like to navigate the route but also show for example POIs of campgrounds, water sources etc.
Another point was, saving a POI in the Ambit Peak saved only the location but not the altitude. Does saving a POI in the Garmin save location + altitude?
How do you load GPX tracks and POIs on the watch? Does it work over Bluetooth? Because in my Ambit Peak, I had to load the GPX into the Suunto app, but then connect the watch with a USB cable to my PC to sync it over SuuntoLink. This was a huge bummer, as it was impossible to load new tracks/alternatives while on the road.
Solar and Battery
Does anyone have some real-world experience with the battery life while navigating only + navigation & tracking?
How long does it take to charge?
