Update:
I updated my watch to 19.10 and it seems that altimeter works now as intended. Did some hiking and biking and so far no strange behavior in sudden spiking/dropping height and therefore wrong calculations regarding accumulated climbing height.
Hello everybody,
I'm one of the people who still sits (again) on Software Version 17.00 because (as far as I know) 17.00 had the best performance/accuracy regarding altimeter. I had the problem in the past that altimeter shows to high numbers because of sudden drops in height which leads to a incorrect calculation after upgrading the software version. Sensor inlet was not blocked/not the reason of the malfunction because switching back to 17.00 fixed the problem directly.
So now i read that 19.10 has been released and I want to ask if meanwhile the altimeter problems are gone/ are not a thing anymore and if it's okay to install 19.10 regarding a proper working altimeter? Altimeter is one feature for me which has to work as good as possible ..
Regards,
Jens
