A plethora of questions about my new watch
Hi all,
This is my first Garmin watch or any smart watch for that matter which I bought it to replace an old Casio Solar G-Shock.
I absolutely love the watch and having spent a couple of days going through the plethora of options and activities I have a ‘few’ questions around the settings and operation etc.
There’s quite a few, so I’ve grouped them into suitable categories. Hopefully you guys can either resolve or shed some light on them.
Any help would much appreciated! Here we go . . . .
Watch face and display
  1. I’d like the date to read two ways on the display, dd/mm as actual numbers, so say 01/12 and DDD/dd/MMM, so say WED 01 DEC. Is this possible? In the ring on the face, I can get, for example WED 1 or DEC 1 which isn’t good enough. On the bottom of the face, I have managed to get, for todays date as example, WED 1 1 DEC. You can’t seem to get the date either as full numerical or with the numerical day sat between the weekday and the month? The setup I have does work as I know the numbers are separate, but it’s very annoying that it doesn’t appear to be as customizable as I was led to believe.
  2. Can you get the face to continuously display the battery percentage rather than just the icon? Currently to get the percentage you must hold down menu then it toggles between the battery icon and the actual percentage. I’d rather have percentage than the number of days left as it’s easier to understand battery drain in my opinion, plus I like to see it as a numerical value.
  3. Can you customise what’s displayed on the widgets like you can the watch face? So, say on the Event widget, it shows WED 1 in the ring, can you modify this to show say DEC 1?
Battery and power
  1. You can make the watch automatically go to battery save mode when you enter the sleep window, however can you make the watch fully shut down instead of just going to battery save mode?
  2. The watch by default has two Power Modes which I can change the settings of. When/how do these modes get selected/initiated and how does this differ from battery save mode?
 Sounds and Alerts
  1. Is it possible to make the watch sound/chine on the hour rather than have it as an alert that display on the screen and vibrates?
  2. When I set the hourly alert to on, come out the menu then go back in, sometimes it says the option is off even though it does alert every hour. Why?
Controls and operation
  1. Why don’t my shortcuts seem to work? They are all set as default, i.e. ABC+GPS = shutdown and SET+CTRL = shutdown, however when I press these either together or one after the other, the watch doesn’t shutdown.
  2. When you use the controls, it seems to remember the last one used rather than reverting to the first in the list. Is this correct or is it time-based or can you select the desired operation?
  3. I get alerts when I’ve reached a goal, however is it possible to disable these alerts rather than having to edit the number and setting it sufficiently high that I’ll never reach it? Seems silly if you can just delete the goal or turn it off.
 App and website
  1. Can you get the watch serial number from connect app? You can get the device ID if you keep your finger held down on the image, but this isn’t the serial. You can get the serial from the back of the watch, via the watch software, via the online account if registered but seemingly not via the connect app?
  2. The watch can calculate my calories burn for the day, but you can add this to the app or online dashboard without having the MyFitnessPal app. Why is this when clearly the watch is capable without? I’ve signed up and linked but it seems pointless when all I want is calories burnt as a value on the app.
  3. Can you change the device alias via the connect app? You can online when you login, but seemingly not via the app or the watch itself.
  4. If I save a GPS location to the watch, can I modify the name via the app or must it be done via the watch? Typing on the phone keyboard would be much quicker and easier than cycling through the phone alphabet letter by letter.
  5. The app and website stated my watch software was up to date (v9.4), yet when I went to the watch settings and checked update, v16.00 was sat there ready for install! Why was this and where can I find more info as to what the update includes?
  6.  Can you upload the settings from one watch to another, just like you can for the Apple iWatch and other smart watches?
Thanks in advance,
Mitch
Top Replies
All Replies
