i use instinct solar APAC... is it normal in 4 days battery drop 9 percent from 100 to 91? no using GPS, off HR and pulse OX, no phone connection, and off activity tracker...thank you
Moved thread to Instinct Solar forum
9% in 4 days would theoretically get you to more than 44 days, so I'd tell it is all right. See the Battery Specifications…
Since 12.2 I get 2 1/2 days on a charge, it uses 1-2% per hour, default settings, master resets performed. Contacted Garmin Support but haven't heard back from them yet.
9% in 4 days would theoretically get you to more than 44 days, so I'd tell it is all right. See the Battery Specifications in your User Manual
The actual battery life depends on the features enabled on your device, such as activity tracking, wrist-based heart rate, smartphone notifications, GPS, internal sensors, and connected sensors (Maximizing the Battery Life).
Battery Life |
Battery Life With Solar |
Mode |
Up to 24 days |
Up to 24 days plus 30 days1 |
Smartwatch mode with activity tracking and 24/7 wrist-based heart rate monitoring |
Up to 30 hours |
Up to 30 hours plus 8 hours2 |
GPS mode with wrist-based heart rate |
Up to 70 hours |
Up to 70 hours plus 75 hours3 |
Max. battery GPS mode |
Up to 28 days |
Up to 28 days plus 40 days4 |
Expedition GPS mode |
Up to 56 days |
Up to 56 days plus unlimited5 |
Battery saver watch mode |
Same drain here
without the sun I get maximum around 14 days. I have not been able to test the solar feature yet as the weather is horrible but anyways I was expecting more than 14 days of battery.
