Can i broadcast form Instict Solar via str3amup! app ?
I have noticed there is watch called "Instinct Esports edition" and app called "Str3amup!" on windows
Would it be possible to broadcast postion, heart rate via that app using standard Instict or Instict Solar ?
mine: Instinct Solar soft12.20, thank you
Top Replies
All Replies
  • Is it possible to download Esports Activity to normal Instinct edition watch to be recognized by Str3amup ?
  • The page Compatible Devices of the STR3AMUP App lists only Instinct Esport Edition, so I guess that answers the question.
    On Instinct Solar you can use Live Track for sharing those values.
  • I've been looking into this just now too. I see that on the watch's filesystem itself there's a folder called 'Primary/GARMIN/Sports' where there's a different .fit file for each activity type (Running, Skiing, etc.).
    If someone has this watch, they can theoretically plug it into their PC, download the 'Esports' file from that folder, and then upload it for others to use.
  • Sir do you have that file ?
  • I see that on the watch's filesystem itself there's a folder called 'Primary/GARMIN/Sports' where there's a different .fit file for each activity type (Running, Skiing, etc.).
    Those are not apps processing the data, rather just defiinition files telling the watch what options it should turn on, when using that sport definition. It would work only if the non-eSports editions supported the STR3MAUP functionality in the firmware, which is not sure at all. On the other hand, you can always try it, just do not be surprised if it does not work.
    Besides that, the FIT files for the sport definition contain also the model name, and the S/N, and may not work at all unless you edit the file to match your device.
  • Hello, does anyone have an answer to this problem? Thank's
