Hrm Run compatibility
Hello,
i found that the HRM Run is compatible with the normal Instinct but is not mentioned the Solar version.
Could someone confirm me if it's copatibile?
Thanks in advance
Top Replies
All Replies
  • AFAIK
    No, AFAIK it is not fully compatible with any of Instincts, because none of the models support Running Dynamics. You can, though, use it as a plain HRM (without taking any advantage of the advanced Running Dynamics features)
    If I am not mistaken, the only HRM that can be used with Instinct and still can provide the Running Dynamics is the HRM PRO, that works as a standalone device.
    EDIT 2021/01/18: There is still some discussion whether the Running Dynamics is available with HRM Pro + Instinct, but unless someone can confirm first-hand that it really works, it is safer to assume that it does not.
  • undertood,but it doesn't give me any running dynamics also in the connect app? I mean, i dont' need it during the run, but after during the data analisys
  • HRM PRO does, HRM Run does not (with Instinct / Instinct Solar).
  • got it, thanks!!!!
  • It works perfect to get data, it records everything, and with good quality.
    The only problem is connect that does not shows that the band was used I guess it is a bug, and not sure if they wat to solve it.
