I have the widget that shows how much solar charge has been picked up, but is there any way of seeing the actual gain?
Like, say, your 30 minute drive to work with the watch in the window gained 3%?
There is no way, i have tested it and it approximately gained 2 percent at 45-60 minutes below 100% sunlight, in battery saving mode, in a glass of water ( to protect from the heat exists from direct sunlight…
I would also find the information on how much additional energy was gained by solar charging very interesting.
Maybe you can include this information in a next update.
There is no way, i have tested it and it approximately gained 2 percent at 45-60 minutes below 100% sunlight, in battery saving mode, in a glass of water ( to protect from the heat exists from direct sunlight. )
I think people could be disappointed if the see something like "you gained 1,25%" after being in bright sunlight, but the instinct needs so less battery, with my settings 2% are enough for almost one day more battery life. (32 days at 100%)
On mine with 2 hours of solar charging I got from 87 days to 170 days, that is 95% :-) However, everything possible is disabled, except the 1 second watch face refresh.
