a blue triangle appeared on the garmin watch when trying to update it, a hard reboot does not help, they also tried to delete the gpe.bit file, but it also did not help, what should I do?
They? You must be talking about Support? If you tried to delete the gpe file then you must have already already tried hooking it up via USB cable to a computer?
yes, they connected it to the computer, deleted the file and did a complete factory reset, but the blue triangle is still lit (sorry for the mistakes, I don't know English well)
I connected the watch, reset the settings, and deleted the file, but nothing worked, watch instinct 3 50mm amoled
If your watch is stuck on the Garmin logo/blue triangle screen and does not proceed any further, reset your device to factory default settings with the below steps.
It is recommended to read the steps below in full before performing them.
