Just got Instinct Solar 3. 10 days battery life only. I've read that a firmware update will fix it. Currently at 5.21.
How do I force the update? It's not happening on its own.
Thanks for any advice.
Sync the device with your phone. Then check on the watch under Settings>Update. You might need to sync the watch a few times or restart it. A few days ago, I couldn't update via garmin express to 6.29 and got the out of space error many others did. I then used my phone and the watch didn't show anything available. So I turned off the wifi connection so the phone would only use LTE and then the update was available on the watch.
That is some great advice. Thank you.
Unfortunately, I ended up using an extra computer we have (I don't run windows) and was able to install and update using Garmin Express. I wish I had seen this answer sooner so I could test it.
Bottom line: I have 6.29 installed now and 40 days of battery life. Thanks again for the reply. I hope someone can test it soon.
