Garmin Express displays the following error trying to install the 6.29 on my Instinct 3 Solar:
"The latest software does not fit on your device's inter memory"
Update February 6, 2025:
Garmin is investigating reports of a Garmin Express displaying an error when updating Instinct 3 Solar device. As a work around, we recommend Adding your Watch to the Garmin Connect…
Update March 24, 2025:
Our engineers have found that the following steps will clear up enough space to complete the software update.
See at my thread here :
It looks like a hardware design problem…
Agreed, the constant issues I have had are enough to make me consider returning the watch. This level of incompetence is unforgivable for a company their size and for a watch that costs nearly 500 dollars…
It seems more than a software bug with Garmin Express. People is saying that even without Garmin Express, all activities and data will be need to be removed due to the low memory available. Needing to remove everything is not very convenient.
The update is available on the watch now through Connect but when I go to install 6.29 it just re installs 6.28. I’ve tried multiple times with the same result.
Unfortunately no such option on my I3 Solar... I am on 5.21 and the only options under "Software update" menu are: (1) "Autoupdate" (on/off) and (2) "What's new". Nothing more... The same in the GCA.
You can clean up the following folders, to make the needed room for the firmware update:
You could also remove some unneeded Connect IQ apps, if there are any
This still happens with version 8.09
I had the same issue. Garmin Express would cause errors. I then did it via my phone and it failed. After I turned on 'Auto Update,' it showed as available and then it installed fine. Try that, if not already.
I returned the watch last month, it's a joke what Garmin is doing...
Hey guys, I had luck with the steps in this post
There is no Garmin drive on a Mac... How is that Garmin still doesn't support the Mac properly??
