Hello guys:
I was searching for bands other than the few offered at Garmin website for my Instinct 3 45 mm.
I know my band is 22 mm
Ebay comes with Quickfit for Fenix ( many models), or other bands at 22 mm
Has anyone try them ?
Hello guys:
@Jonathan and 8659452:
I tried the 26 mm loop nylon bracelets from Yooside for the Instinct 3 Solar today. They fit, but are harder to put on. You have to press the band under the pin with a little more…
Update: The silicone band does not cover the flashlight either. However, it sits directly under the light, whereas the nylon band has some space.
The challenge will be finding one that doesn't obscure the flashlight, unless that's something you're not bothered about.
I tried the 26 mm loop nylon bracelets from Yooside for the Instinct 3 Solar today. They fit, but are harder to put on. You have to press the band under the pin with a little more pressure and then pull the band through in a zig-zag course like a skier.
A silicone band with a quick fit fastener from Yooside also worked. But here too it was harder and could only be put on at a certain angle.
At least with the nylon bands the flashlight works perfectly. I forgot to check the silicone band. I'll do it again in a few days.
Then the 22 mm should actually work too.
