The battery lasts 24 hours, which I find unacceptable.
As mentioned previously, I also had battery drain and HRM malfunction with the 17.07 update. I was on 16.11 before that. Just to log what I've tried:
- Tried factory resetting
- Tried re-applying 17…
I've tried these steps and unfortunately has not improved the situation. I am using my Garmin exactly how I was before the 17.07 update and am seeing drastically reduced battery life. Are you able to share…
I've tried troubleshooting several times, but nothing helps. The watch drains about 5-6% of its battery per hour of use. Please help me fix this battery drain issue.
Please try the troubleshooting steps in this FAQ we've created to see what may be causing a faster battery drain for your Instinct 2.
Why Is the Battery of My Garmin Watch Draining Faster Than Expected?
If you continue to experience battery drain after trying that troubleshooting, please get in touch with our support team here.
I've tried these steps and unfortunately has not improved the situation. I am using my Garmin exactly how I was before the 17.07 update and am seeing drastically reduced battery life. Are you able to share if Garmin are aware of anything specifically related to the 17.07 update that might be causing this and whether we can expect a fix? Or is the advice at this stage to contact support directly?
Are you saying this is not a firmware issue?
Are all these people lying, perfectly timing their complaints to the update date?
www.reddit.com/.../
Same here on my Instinct 2X. At first I thought the battery was dead, so I ordered a replacement from Aliexpress – it costs just a few euros and the swap is pretty easy.
But even after installing a brand-new battery, the exact same thing happens: instead of 40 days, the watch barely lasts less than 24 hours.
So it’s clearly not a hardware/battery issue. There must be some kind of software/FW 17.07 problem, because the drain started right after the update and changing the battery doesn’t fix anything.
