Softwareversions for Instinct Crossover
Hi,
I  bought a crossover just 4 weeks ago and it showed a softwareversion 3.10.
Now it seems a 16.11 version has been automatically downloaded and is waiting to be installed...
I am now wondering: Have there really been 13 main-versions since the launch of the crossover??
And since any kind of update always comes with some risks: can anyone tell me whether these 13 versions were worthwhile? I haven't noticed any issue as of now that would have varranted an update...
Thanks for any input!
Top Replies
  • And since any kind of update always comes with some risks: can anyone tell me whether these 13 versions were worthwhile? I haven't noticed any issue as of now that would have varranted an…
All Replies
  • Hi,
    Greetings!
    I bought my Instinct Crossover in December 2022, it had Software Version 2.04.
    There have indeed been many software updates over the last 2 years so that I am now running Software Version 16.11 which I installed last August.
    In my experience, every update was better than the one before. Stability and functionality are better with the latest software.
    I strongly encourage you to update to the latest Software Version 16.11 - it is the best option to assure continued reliable operation of your watch.
    HTH
  • And since any kind of update always comes with some risks: can anyone tell me whether these 13 versions were worthwhile? I haven't noticed any issue as of now that would have varranted an update...
    Just a short note further to my last:
    Since there have been numerous updates since your version 3.10 like Time Zone Maps, Language files, Sensor Hub software, etc., not just system software, I would strongly suggest plugging into a computer running Garmin Express and updating ALL your software that way.
    Using Garmin Express with a hardwire connection to your computer can avoid many issues that might arise updating so much software wirelessly.
    HTH
  • Thanks for your input, really appreciated!
    Eventually, I didn't have much of a choice as the watch just went ahead and installed the already downloaded Update. I thought I would have had the final say on whether or not to actually install it, turns out it wasn't the case. So 16.11 is now installed and all seems normal...
    What would you say were the major feature additions across all these updates that I should now check out?
  • What would you say were the major feature additions across all these updates that I should now check out?
    Well... Since you asked:
    Instinct Crossover System Software 11.18
    Change Log
     Added the Grade Adjusted Pace data field that displays your average pace adjusted by the steepness of the terrain.
    Added running power data to activities without the need for a running dynamics accessory.
    Added the backcountry snowboard activity to the list of available activities.
    Added a morning report when you wake up that features the weather, your sleep summary, HRV status, and more.
    Improved the backcountry ski and snowboard activities to automatically detect climbs, descents, and transition time.
    Improved daily workout suggestions to help you train for events on your Garmin Connect calendar.
    Added support for Sleep Mode.
    Added support for Primary Wearable and Primary Training Device (Unified Training Status).
    Added Simplified Device Pairing Experience.
    Added support for configuring activity alerts in GCM.
    Added option to delete Strength workouts.
    Added temperature recording activity setting.
    Fixed issue where daily active calories total could be incorrect.
    Fixed issue where Indoor Bike activity could start on wrong data screen.
    Fixed distance discrepancies in Reference Point app.
    Added ability to customize Do Not Disturb mode settings.
    Added prompt to select activity profile when launching a workout from the Calendar glance.
    Fixed GCT Balance data field font size.
    Fixed issue where a random value could be displayed on the Edit Reps page.
    Fixed sleep data uploads through Garmin Express.
    Fixed possible crash on Edit Set page.
    Fixed issues with compass calibration.
    Fixed lock/unlock banner not displaying on watch face.
    Fixed issue that could cause CIQ watch faces to crash.
    Fixed issue where CIQ watch faces would crash after alarms.
    Fixed CIQ number font mapping.
    Instinct Crossover System Software 12.25
     Change Log
     Added Obstacle Course Racing activity.
    Added setting for automatic sensor discovery in Sensors & Accessories menu.
    Improved algorithm for calculating calories burned in Swim activities.
    Improved voice prompts played during activities.
    Fixed issue where an abnormal high HR alert could be triggered while broadcasting heart rate.
    Fixed issue where Track Run alert distance would not display in meters.
    Fixed issue in Fish activity where location was not saved when logging a catch.
    Fixed potential issue with activity Power Mode Auto Enable setting.
    Fixed potential issue where Edit Reps prompt would not appear during Strength activity.
    Fixed Timers list page issue where only allowing 8 timers could be configured.
    [Tactical] Fixed issue where HR Broadcasting could be enabled in Stealth Mode.
    Fixed issue with Cycling FTP detection.
    Fixed issue with workout names being truncated.
    Fixed issue where a hot key press would exit the Incident Detection or Assistance countdown page.
    Fixed issue with End Sleep prompt when accessed through Training Status glance.
    Fixed issue with saved locations list.
    Fix incorrect workout interval timer time.
    Fixed issue with HIIT custom timer number picker.
    Fixed issue where Daily Suggested Workout entry would display in calendar glance after it was completed.
    Fixed issue where Daily Suggested Workout prompt would continue to display after it was completed.
    [Tactical] Fixed issue where watch would not reconnect to GCM after disabling Stealth Mode.
    Fixed issue with Air Quality page when temperature units are set to Celsius.
    Fixed potential issue with HRV status indicator.
    Fixed potential issue where activity power mode could not be set.
    Fixed potential crash in Virtual Run activity.
    Fixed Morning Report issue that prevented viewing calendar details.
    Fixed potential issue with Morning Report Steps Goal page.
    Fixed location data field position.
    Instinct Crossover System Software 13.19
    Change Log
    Added Gaming activity.
    Added Tides Glance.
    Added Workouts app.
    Fixed connection to Bluetooth sensors in CIQ apps.
    Fixed saved location names not displaying on map.
    Improved compass smoothness on the compass page.
    Fixed recovery time discrepancy between glance and widget.
    Fixed CIQ watch face crash when using Sleep Mode hot key.
    Fixed issues with Expedition post activity summary pages.
    Fixed GCT Balance data field.
    Instinct Crossover System Software 14.12
    Change Log
    Removed the limitation on the number of points allowed in a course.
    Updated Backcountry Ski/Snowboard data screens when using Automatic Mode Tracking.
    Fixed issue that would prevent access to Team Sports activities.
    Fixed issue that could cause Edge devices to crash when used as extended display.
    Fixed issue where golf handicap would not display in Connect.
    Fixed issue with Intensity Minutes Heart Rate Zones.
    Fixed potential crash when using PacePro.
    Fixed crash when replying to smart notifications.
    Fixed Next Waypoint data field blank when using turn notifications.
    Fixed Track Run GPS setting.
    Fixed issue where Strength activity name could be truncated in GCM in German.
    Fixed issue where pickleball and padel could not be accessed when Auto Cal is disabled.
    Fixed cadence spikes during open water swimming activities.
    Fixed potential issue where step totals would not reset at midnight.
    Fixed various issues in Ski and Snowboard activities.
    Instinct Crossover System Software 15.08
    Change Log
    Fixed issue during workouts where incorrect page would be pushed after editing reps.
    Ensure training load is properly calculated when using the Store & Forward feature on supported Garmin HRM straps.
    Fixed crash when editing alerts in XC Ski activities.
    Fixed location distances in Reference Point app.
    Fixed potential issue where distance could stop counting during GPS activities.
    Fixed map drawing issue.
    Various bug fixes and improvements for Ski and Snowboard activities.
    Fixed Hydration auto goal.
    Fixed potential issue with Dog Alerts.
    Fixed potential issue where distance could stop updating in pool swim activities.
    Fixed display issue on Fitness Age screen.
    Instinct Crossover System Software 16.10
     Change Log
    Fixed issue with Battery Saver watch face where time would not update correctly.
    Fixed issue where inReach screen could be displayed after using the Health Monitoring app.
    Fixed issue where data could be covered up on activity summary page.
    Fixed issue where high/low temperature could be truncated on Morning Report page.
    Fixed issue where Bouldering rest timer could be truncated.
    Fixed issue where Strength activity timer could be truncated.
    Fixed issue with Sight ‘N Go hot key when accessed outside of an activity.
     Have fun!
    HTH
  • Oh Lord...
    Doesn't give me that warm and cosy feeling seeing how many times it states "Fixed ..." but hey, better have a fix, right?
    Thanks for that thorough compilation
