Problem with heart rate sensor
I have a solar Garmin Instinct 2x and a coospo heart rate bracelet. Every time I run with the bracelet it disconnects and connects continuously, it doesn't matter if it's connected by bluetooth or ant +. Does anyone know why it happens?
  • Check the battery of the Coospo. What have Coospo to say about the problem?
  • First of all, I would try changing the battery in the bracelet. Also, wear the bracelet on the same arm as the watch. If it does not help, try connecting the strap simultaneously also to the phone. You can do it for example with the Strava app. If you get dropouts there too, then there is a problem with the bracelet, and you will need to contact the vendor, or Coosco's support. If there are no dropouts on the phone, there is either a problem with the watch, or some compatibility problem between the two devices. In such case I would recommend contacting the support on both sides.
