Instinct 2x solar - upload failed
Dear all,
I'm an owner of Instict 2x solar, connected to Garmin Connect.
Since a couple of weeks ago I was able to synch every day my garmin with connect by bluetooth.
Since then I'm facing upload failed as per below report from Connect:
---GCM App Version---
5.6
---Timestamp---
Thu, Oct 31 2024 @ 9:39 PM
---Garmin Device Info---
[device information] unit id:removed by me, product number: removed by me, software version: 1611, device name: Instinct 2X Solar
---Android Device Info---
OS: Android
Ver. Release: 14
Ver. SDK: 34
Ver. Codename: REL
Locale: it_IT
Manufacturer: samsung
Brand: samsung
Model: SM-S926B
Device: e2s
Display: UP1A.231005.007.S926BXXU3AXH7
Hardware: s5e9945
Host: 21DKG916
Product: e2sxeea
Radio: S926BXXU3AXH7,S926BXXU3AXH7
Serial: unknown
Tags: release-keys
Type: user
User: dpi
Board: s5e9945
Bootloader: S926BXXU3AXH7
Supported<br/>ABIs: arm64-v8a<br/>
---Sync Info---
******************** SYNC RESULT ********************
Upload Status=FAILED (Failed to read file from device)
Download Status=FAILED (download:ERROR PRIOR TO EXECUTE)
Time Sync Status=SUCCESSFUL
Overall Sync Status=FAILED
Origin=5037_SYNC_REQUEST_MESSAGE__VISIBLE_IF_FILES
UPLOAD:
LISTED (Supported=[4, 32, 38, 44, 41, 49, -11, -8, 58, -9, 68, 70, 72, 74]; Uploadable=[FIT_TYPE_71, FIT_TYPE_70, FIT_TYPE_73, FIT_TYPE_72, GPSData, FIT_TYPE_52, FIT_TYPE_74, KPI, FIT_TYPE_77, FIT_TYPE_32, FIT_TYPE_35, FIT_TYPE_57, FIT_TYPE_79, FIT_TYPE_58, FIT_TYPE_38, FIT_TYPE_9, FitnessHistory, IQErrorReports, GOLF_SCORECARD, BACKUP_SUPPLEMENTARY, FIT_TYPE_61, ErrorShutdownReports, FIT_TYPE_41, FIT_TYPE_44, FIT_TYPE_66, FIT_TYPE_68, BACKUP_PRIMARY, FIT_TYPE_28, FIT_TYPE_49, FIT_TYPE_4, BLELogs, ACTIVITY_GCPD, ULFLogs, WELLNESS_TYPE_1]) { listed=5519ms }
- 81 (80/MONITORING_B/599B): ARCHIVED { extracted=320ms posted=281ms archived=76ms }
- 113 (80/MONITORING_B/591B): ARCHIVED { extracted=256ms posted=370ms archived=79ms }
#Auto Upload=true
#Types=[4, 32, 38, 44, 41, 49, -11, -8, 58, -9, 68, 70, 72, 74] | [FIT_TYPE_71, FIT_TYPE_70, FIT_TYPE_73, FIT_TYPE_72, GPSData, FIT_TYPE_52, FIT_TYPE_74, KPI, FIT_TYPE_77, FIT_TYPE_32, FIT_TYPE_35, FIT_TYPE_57, FIT_TYPE_79, FIT_TYPE_58, FIT_TYPE_38, FIT_TYPE_9, FitnessHistory, IQErrorReports, GOLF_SCORECARD, BACKUP_SUPPLEMENTARY, FIT_TYPE_61, ErrorShutdownReports, FIT_TYPE_41, FIT_TYPE_44, FIT_TYPE_66, FIT_TYPE_68, BACKUP_PRIMARY, FIT_TYPE_28, FIT_TYPE_49, FIT_TYPE_4, BLELogs, ACTIVITY_GCPD, ULFLogs, WELLNESS_TYPE_1]
Removed manually all activities without any change.
From Garmin Express on my win PC i can sync without any error.
Do you have any suggestion in order to fix it?
Looking forward to hearing from you,
Ste.
Top Replies
  • Hello
    I am sorry to hear you are having this issue. For this, there are some additional troubleshooting steps I would recommend trying.
    • Ensure the phone is on the latest OS version.
    • Try pairing…
All Replies
  • Hello
    • Try pairing the watch with the phone again with these steps:
    1. Uninstall the Connect Mobile app
    2. Clear the phone cache and history
    3. Ensure the watch does not appear in the phone's Bluetooth menu. If it is, please remove the device
    4. Powercycle the watch and phone. To do this, hold the Light button until this shuts off. Then power on again
    5. Reinstall the Connect Mobile app
    6. Try the pairing again ( Be sure there are no other Bluetooth enabled device nearby)
    To pair, place the watch in pairing mode. Sign into the Connect app, and allow this to walk you through the pairing.
    If this is still not syncing with the app, I would recommend completing a factory reset on the watch, then try again.
    1. Ensure the watch is powered off.
      • You may need to hold CONTROLfor up to 30 seconds to turn the watch off.
    2. Press and hold SET and GPS.
    3. Press CONTROL to power the watch on while holding these two buttons.
    4. After the first beep release GPS.
    5. After the second beep release the remaining button.
