Like other people here on the forum, every time I unplug my Instinct from USB I have to reboot it or solar charge won't work (even after battery drops down). It is quite annoying, has anyone found a solution?
(software version 16.10)
You can use a wall charger to avoid the issue. But anyway doing a hard reset whenever I plug the watch into the computer has become a routine for me.
It happens also after I unplug it from the wall charger :/ So it's pretty much a hard reset every time that I charge it
Oh, let me double check next time I wall-charge it. I guess the good thing is my I2X lasts a month with my usage patten.
Hi. Was there any update to this issue. I see the same issue. Also my battery is dying quite quickly. It shows 13 days and in the morning it will show 5 days, and within the day it will say battery low.
Thanks
Any update on this issue. I have been having this issue for over an year now. It all started after a software update. Since the update my batter also started lasting only like 5 days even for normal usage. It will show 13 days in the night and in the morning it will go to 5 days. Feels like they messed up the software.
wouldn't it be easier to reboot after charging via pc? or charge with separate charger? as much as it's bug, there's workaround, so might be worth using it. i do it too and i guess most do too.
otherwise if you see 5 days of battery, that's not software, i see 44 days on full charge. either it's settings you have or simply your battery is gone. not exactly sw issue
