Well done, Garmin. My Instinct 2 suddenly stopped recording distance. Any clue of what could be wrong? This is the first time it happened since I bought it.
What parameters do you have set for the Hike App?
I used the default settings for the Hike app. Is there anything in particular I should look for?
Could you share a link to the activity? It may help seing where the problem may be coming from.
Hm, indeed strange. I see no usual suspects:
The distance works only the first 120s of the activity (17 trackpoints), where it stopped at 113m. Unfortunately, I do not see why.
To fix this specific activity, you can edit it, and change the total distance to 6.46 km. Then test another short hike (just a few minutes), and see whether the problem persists. If it does, then do the soft reset of the watch - sync, then hold the Light button for 30s (keep holding through the assistance alert!) till the watch shuts down, then wait a few seconds, and restart. No data and no settings get lost.
If it does not help, you should try the master reset to factory defaults. And if it does not help either, then reach out to the Support through their website at https://support.garmin.com
Thank you very much for your time and such a detailed explanation. It helps a lot. I'll do as you suggested.
