Problems with weather updates or weather display
Hello,
The 1st problem: no weather is displayed in the morning. The weather data only appears when I run Garmin Connect. iPhone 15 pro, location is set to - always, background refresh - turned on and everything has full access.
The 2nd problem: Temperature display for the day (from... to...) does not match the current weather display.
Top Replies
  • The weather data only appears when I run Garmin Connect
    That's correct, Garmin Connect must be running in order to be able updating the weather data. Running in the background is sufficient…
All Replies
