I'm not sure if this is the best place to report bugs but....
I have the hot keys setup so that GPS and down is change sport, I've used this for multisport events however I've noticed changing sport sometimes crashes the watch.
Yesterday I did an event with 10 sport transitions, using the hot keys, I switch sport profiles at each transition. This worked well up until about the 8th sport, then the watch seems to reboot a few minutes into the new sport. When the watch reboots, the activity restarts but in a paused state which is kinda annoying.
So the questions are...
- Is there a limit to the number of sports than can be added in this way?
- Is there the possibility of adding an option for "Auto resume after reboot"?
- The multisport profile allows you to setup a profile with the sports in advance but is limited to the number of sports you can add, could this be expanded to infinite amount of sports?
- Could a transition option be added to the "Change sports" menu, similar to the way you can set transitions in the multisport profile?
Unrelated to this, I also have a Edge 130+ and tried to use the Extended Display function for the biking sections, it just showed blank on the Edge and then the edge rebooted, I don't know if this is an edge problem or an instinct problem.
SW: 13.21 (e5694b9)
GPS: 6.70
CIQ: 3.4.2
BMX: 13.0.3
BLE/ANT: 1.04
SNS: 25.60
