Disappearing seconds on a watch face.
Can we disable or put a setting that will keep the seconds on a watch face at all times? I understand it's a power saving feature but a lot of times I just look at my watch without raising it to my face so the move sensor doesn't trigger, and even then the lag is annoying.
There are watch faces without the seconds if I want it like that.
It really gets in the way.
  • There is a way how you can keep the seconds on all the time - start an activity and keep it running in the background. As long as the activity is in progress, seconds will keep on changing.
    A Connect IQ watchface might perhaps be another possibility. Try some and see whether some of them can bypass this limitation.
    Otherwise, you can also suggest adding a setting for that feature to Garmin at Share Ideas | Garmin
  • You can try "GLANCE watch face" from Connect IQ. It has an option 'Always display seconds (uses more battery)'.
    Or you can bump or tap the watch, the default watch faces are sensitive to any kind of movement, not only raising the watch, I personally hate this.
