Hello, after update to 13.19 on my garmin solar instinct 2, solar charging doesnt work. Does anyone have a problem with this?
Mine works. But I did soft reset right after updating.
If you recharged upto 100% some times watch will not start solar charging even if the battery percentage goes below 90%. The solution for this switch off and on.
I also have the same problem. Every time I charge with USB to 100% the solar charging stops working (even after letting the battery drain a bit). If I turn it on and off, it works again. I hope it gets fixed though, as it’s annoying to remember to reset after charging.
forums.garmin.com/.../instinct-2---solar-charge-not-working-after-usb-charge
