I know there’s a Garmin app in the App Store but obviously this doesnt work with the I2, curious if a Stryd pod actually works with an I2? Can’t find much online
Did you ever figure this out?
Stryd mentions the Instinct 2 on their docs:
These watches will only support the Stryd Zones Data Fields.
Instinct 2 Series
But I'm not sure this means it will allow for zone updates or workouts
Instinct 2 does support connect iq.
The Stryd Zones data Field supports Instinct 2. So there should not be a problem.
You need to add to add it to one of your displays. There is also an activity setting for running power, where you can set the source of running power. Automatic should be default.
I recall it being a separate IQ field, not Garmin-approved power, which it would pull from something like the HRM-Pro
help.stryd.com/.../6879672-garmin-native-power-is-different-than-stryd-power
It is and that is also what I saying:
https://apps.garmin.com/da-DK/apps/18fb2cf0-1a4b-430d-ad66-988c847421f4
Here you can make sure that external power is used:
I was pointing out that the "external power" setting will not use Stryd under any circumstance. Garmin does not recognize Stryd as a power sensor. It uses a GarminIQ field, which is completely separate from what Garmin labels as "Power".
That "external power" setting is for the Garmin HRM Pro or other Garmin Accessories.
