When daily suggested workout prompts are enabled, if the workout for the day is completed it seems to take two "GPS" button presses to get into the run activity instead of just one, as if the daily suggested prompt is 'blocking' the run activity access (even though nothing is shown after the first press).
Steps to reproduce:
With daily suggested workout prompt enabled:
1. Press GPS
2. Select run
3. Press GPS (nothing happens)
4. Press GPS (run activity is accessed)
Step 3 is where the problem is, should skip right to 4 normally. If I disable daily suggested workout prompts it works fine
Instinct 2 standard edition with software latest release v12.25
