After update my Instinct 2 solar last night to 13.13 battery shows still %100 from last night nothing changed any idea what it should be any glitch with new version?
Did you try soft-resetting your watch?
How to Reset My Garmin Outdoor Watch | Garmin Customer Support
After the reset, charge the watch for a few hours, and then keep it running till it completely discharges. That should restore the battery gauge calibration.
Yes I did the thing is yesterday afternoon it went 99 percent and seems like it may change but very slow I’m not sure if it’s battery drain slower or it’s showing wrong percentage because before battery more or less 3 to 4 percentage less everryday
Hello, if you switch to "day" view instead of percent left, does it change after a while?
It’s changing slow if compare previous version I had if this is correct battery level that’s very good in 3 days only shows %96 percent battery and 41 days from 44 so seems like daily base show correct as well , before it was nearly 3 to 4 percent lowest daily. If this is constant and correct I would be happy . With my settings full charge was around 25 days to 30 days between charges and if this increased with this update that’s sound amazing.
Having this issue with my Instinct 2x as of two days ago. Still on 12.26 software.
I have the same issue. I charged my Instinct 2X on Friday and until today (Monday) with heartrate and bluetooth on the battery is stillin 100%. The Battery Guesstime shows no consumption at all.
Lux hours are low for infinite battery (47k average). I tried soft reset but nothing changed.
Any tip?
Thank you.
currently happening to me. charge the battery wednesday, now friday with 2 days of GPS activity (1hour) and still 100%. i check the the test mode and it says 100% also. i did the restart multiple times, will try to observe up until 5 days, will it seems normal glitch?
Same is happening with my I2X as well. My watch is only a month old, so it was the third full charge after it stuck on 100%.
update: now working, it now drained 3% after an activity it took 3 days and 3 activity to drain, i just let it be,
