Instinct 2x how much percentage is spent while running in multi gnss, all system mod gps?
Can someone test it or already did it?
  • Depends how long you run and how much solar energy you get, and also on some other parameters, but the specifications tell 27 - 36 hours in the multi-band-all-satellites mode (the later with full solar support), which means approx. 36 times (resp. 27 times for the full solar support) faster discharge than when in the Smartwatch mode without any solar charging. Or about 0.9% - 0.7% (in ideal case) discharge per hour. Then you have also the Max Battery, Ultra Trac, and Expedition modes with different discharging rates (see the specs below).
