Hi all, I've just picked up the Instinct Crossover Solar and wanted to check if others are experiencing 2 issues that I've found:
1.) Watchface data fields not scaled to fit display (cut-off)
I'm experiencing data being cut off due to it not being properly scaled to fit the display. For example, using the default watchface the current date does not fully fit (the "0" in "May 10" is partially cut off). If I try adding in custom fields (bottom 3 slots) I get the same issue sometimes.
2.) The windage arrow issue has been resolved by Dan in the below comments; it was a misinterpretation of data on my part.
Thanks in advance.
