Ordered my Instinct 2x and I'm looking for a compatible screen protectors. What is the glass diameter?
I measure 36.51mm on my Instinct 2X Solar Tactical, so probably something a bit smaller would be the best diameter for a screen protector.
HTH
Is it curved as the Instinct 2 screen or it's flat? Instinct 2 is not compatible with rigid glass screen protector.
It's flat, SuperShieldz sells some nice glass screen protectors that fit well on Amazon pretty cheap. Just search for the ones by them that specifically say they're compatible with the 2X.
great news! Do you think glass screen protector can affect the solar charging?
It doesn't appear to have any effect for the glass ones, the lux hours meter still seems to tick up by the same amount every time it refreshes when in direct sunlight. I was concerned about that as well so I tested it before and after on the same sunny day.
36mm. I have bought a generic 36mm screen protector for mine and it fits perfectly. They are also cheaper than the Instinct 2X dedicated ones.
Exactly the answer I was hoping to get!thanks!
Forerunner 745 screen protector fits perfectly. I use that
