Instinct 2 Pace Pro Restarts
Hello, I have a problem with the pacepro function. Shorter distances up to 1/2 m work. When I create a longer route, for example over 50 Km on the maps and export the GPX to connect and create a pacepro, the watch restarts after turning it on while running. The same problem occurs even if I have a route created in app connect, or if I download an already created route in a GPX file. The watch resets after accepting the pace pro plan and it doesn't matter if I turn on the navigation or not. I tried both, running and trail running and the result was the same - the watch restarted. I don't know what to do anymore, so I'm writing to see if you can advise me. I have v 9.23 Thank you.
