[feature request] add temperature sensor data in ABC menu
Please add temperature readings and history graph to ABC menu like it already was in the Instinct 1. Now theres only elevation, baro and compass there.
  • Temperature reading and history is still available in an independent glance & widget, and as far as I remember it was exactly in the same way on Instinct 1.
    Not sure whether it changed at Instinct 1 at the last versions (I do not use it since this March), but I am almost sure the temperature reading was never in the ABC menu. It was an independent widget too. ABC finally stand for Altimeter-Barometer-Compass, so even the name does not imply any temperature reading.
