Fenix 7 Up/Menu botton stop working
Hello, I have a Fenix 7 standard fw 21.19 and from yesterday I have a problem with this button, I tried to put the watch in hot water to clean, but nothig is changed.
If I push the botton it make the “clic” sound than it fisically work, but the comand doesn’t work.
I haven’t tried a reset because the reset is in the setting menu and the botton doesn’t work.. anyone that have a suggestions for this issiue?
Thanks
Top Replies
  • I haven’t tried a reset
    If you want to give the reset a try you may test the Hard Reset using the Three Button Method:
    1. Hold the watch with the two buttons facing down so that you can hold down…
All Replies
  • Hi, I have the same issue from yesterday 23.08 β software version. I turned on the touch screen in order to use the watch but the start stop button isn't respond. I reset to default with no luck...also warm water nothing change...
    thanks
    1. Hold the watch with the two buttons facing down so that you can hold down the two buttons with your thumbs:
    2. Make sure the watch is turned off the hard way by press and hold of the LIGHT/POWER BUTTON for up to 30 seconds (showing "The Reel" & "Garmin Help" in between, keep pressing) until it is off.
    3. Press and hold the BACK and START/STOP buttons.
    4. Press the POWER BUTTON to turn on the watch while holding these two buttons.
      1. After the first beep, release START/STOP.
      2. After the second beep, release the remaining buttons.
    The reset is successful when the watch completes the power-on process and goes through the initial setup. If you don't see the initial setup, try the steps again.
    BUT: from what I read here often I'd still say that your up button is gone. However:if you contact Garmin Support they will have you doing a factory reset anyway so you don't loose anything by trying.
  • Thanks for the tip. I finally decided to call the Customer Service and I sent the watch in for a button repair, I received a confirmation of the repair and it should be back to me in the next few days
