What features will the Garmin HRM Pro Plus strap bring that I don't already have?
So I ride, run, do weights and cross country skiing. I have a Fenix 7S Pro, Edge 840, Garmin cadence sensor on my bike, Garmin footpod on my running shoes and a Wahoo Tickr strap (basic one, bought in 2016).
Since I always wear my watch and Wahoo strap for all my activities, foot pod while running and Edge/cadence for riding, what features would "upgrading" to a Garmin HRM Pro Plus strap, beside the cross country power metric bring me?
  • - for running: Ground Contact Balance (% left foot / % right foot) running dynamic, which is unavailable from the wrist
    - dynamic HR source switching, which some would say is an anti-feature: it dynamically switches to the wrist HR when the watch deems that the data from the strap is somehow unreliable. [This is distinct from the normal feature which switches to wrist HR if there's a literal signal drop out and/or you stop wearing the strap.] Users, including myself, have found that this feature tends to actually prefer bad wrist HR over good chest strap data, in some cases. Note that this feature can still be turned on with an unsupported / non-Garmin strap [like your Wahoo Tickr]: in this case, at all it does is cause both the external HR and wrist HR to logged to the FIT file [as well as the standard activity HR], but afaik, it will not actually perform any dynamic switching
    - maybe better support for HRV than your old Wahoo Tickr, which might be useful if you want to use the health snapshot feature with a strap or you want to use a phone app to measure your HRV via strap
    Things which probably don't apply to you but are worth noting anyway:
    - the strap can be optionally used as a source for speed and/or distance (just like a footpod), although it will refuse to do so if a footpod is also connected. This probably points to the fact that Garmin thinks a footpod is a better source for those metrics but idk
    - Garmin watches support treadmill calibration when the strap used as a speed/distance source, unlike footpods
    - if you wear the strap while not wearing the watch, it will collect "activity tracking data" like all-day HR, calories, intensity minutes, and steps, to be synced to Connect, then back to your watch via physio trueup. You can actually take advantage of this feature to wear the strap but not the watch during a timed team sports activity like basketball - in this case, steps would normally not be counted (as Garmin won't use the footpod as a source for steps). But when you wear the HRM-PRO/PRO+ but not the watch, steps will be counted and synced to Connect, then back to your watch, even if you were recording an activity at the time and even if the strap was connected to the watch during the activity
    - the strap will also store HR data during an activity when the watch is not worn - after the activity, the watch will prompt you to download the data from the strap. This is usually meant for swimming but could also apply to team sports like basketball. The annoying thing is that it will *also* do this if you wear the strap but not the watch during an activity, *and* the strap is connected to the watch during the activity [meaning the watch already records HR directly]. The problem here is if you accidentally allow the watch to download the HR data and merge it with your activity, it can actually corrupt your activity HR data. So this is kind of a pain in the "team sports" use case, because you have to remember to cancel the process of downloading external HR data after the activity
    Also, if you're curious about HRM600:
    - this adds step speed loss (with a compatible watch like FR970)
    - this adds the ability to record a timed activity from the strap itself (no watch necessary). The process is kicked off by pressing a button in the Connect phone app, but the strap doesn't need to stay connected to the phone afterwards
  • Thanks for the very detailed explanation.
    Yeah, team activities aren't really my thing so these are kinda irrelevant to me and although I like to swim, I never was able to swim for long as I tend to sink instead of floating lol.
    Through the footpod, I do get Cadence, Stride Length, Vertical Ratio, Vertical Oscillation and Ground Contact Time. What other running dynamic would there be? And yes, my footpod allows for treadmill calibration. Maybe it's something they removed from newer ones but my 2017 footpod allows it.
  • You get most of the running stats just with your Fenix 7 S Pro. I was using a Garmin Running Pod previously but no longer bother.
    Oh - it also does Treadmill calibration.
  • Hmm, I just checked the runs I did at the cottage with just the watch and my old running shoes (without the pod) and I get the same data as with the pod, interesting.
    However, without the pod, my treadmill walks (not runs) speed is all over the place.
    That's because most running dynamics come from a supported Garmin chest strap, Garmin Running Dynamics pod, or from the wrist [*]. The only running dynamic that comes from a standard foot pod is cadence.
    [*] this was only added to Garmin watches a few years ago. Prior to that, you had to have a supported Garmin chest strap (like HRM-RUN) or RD pod for anything more than cadence.
    Like I said: ground contact balance - percentage of time spent on left foot and percentage of time spent on right foot.
    Garmin chest straps can measure that because the strap's module is centred on your body, the watch itself can't because it's on your wrist.
    Hmm, interesting. When I run on a treadmill with my Stryd connected as a foot pod, I don't see the treadmill calibration feature. Maybe Garmin only allows this with Garmin foot pods? Maybe I'll dig up my old Garmin foot pod and try it out.
    Probably because you're barely swinging your arms while you walk, so speed from the wrist is even more unreliable than it would be for a treadmill run (where you would probably be swinging your arms regularly). A foot pod that's attached to your shoe wouldn't have the same problem.
  • I already opened an incident with Garmin regarding the fluctuating speed while on my treadmill. My arms are balancing enough to keep accurate track of my steps (manually counting them matches exactly the recorded steps) so it's something else. Garmin wants me to dona full reset of my watch but I haven't done it yet.
    Thanks for the extra description of the strap. It might just be my father's day present for this year Slight smile
