Sailing to a waypoint using Fenix 7
Wonder if anyone can help.
I am using the Garmin sail app to navigate to a single waypoint with the following app config attributes
Routing activity : Direct Routing
Courses : Use Map
Type : Bearing
On my old Garmin Foretrek 101 it had a turn data field that showed how many degrees Left or Rght of the waypoint you were traveling but i cant work out how to show this on the Fenix. For the minute i am using the following data fields and having to do it in my head, the difference between Bearing and GPS heading seems to be the Left or Right degree i am looking for.
Speed
VMG
Bearing
GPS Heading
Any help would be appreciated
  • Using the App Builder 5 to create a datafield and setting the Compass to GPS mode the following formula seems to work ;
    If(Bearing-CourseOverGround gt 180, CourseOverGround-Bearing + 360 + ' LEFT',IF(Bearing-CourseOverGround gt 0,Bearing-CourseOverGround + ' RIGHT',IF(Bearing-CourseOverGround gt -90,CourseOverGround-Bearing + ' LEFT',Bearing-CourseOverGround + 360 + ' RIGHT')))
    Hope this helps another sailor
