Tactix 7 System Software Version 21.19
Hello Tactix 7 users,
We have fully released System Software 21.19.
Change Log
Added Breathing Variations Support.
Added unlock icons to sensor details page.
Fixed audio prompts reverting to English after power cycle.
Fixed body battery and stress disappearing from glance history.
Fixed CIQ watch face lag during screen transitions.
Fixed custom text responses resetting to default.
Fixed device automatically reentering sleep mode when manually ended.
Fixed ending and tracking naps started without a nap timer.
Fixed GameOn app not pairing.
Fixed Golf activity not showing yardage to hazards in tournament mode.
Fixed Incident detection activating during unsupported activity types.
Fixed nautical display units on activity summary.
Fixed possible crash in the Garmin Coach widget.
Fixed possible crash when moving golf pin position.
Fixed short distance during run and walk activities.
Fixed strength activity weight being changed on the rep edit and weight screen.
Fixed Taiwan coordinate issue.
Fixed translation issue on the sleep watch face.
Improvements to secure sensor pairing menus.
Improvements to golf club sensor menu.
Miscellaneous fixes for Live Activity.
Updated Running Track Database.
Updated Translations.
Various bug fixes and improvements.
  • This release broke my entire experience. I have lost my watch face, my battery is draining at a 3x rate. How do I roll it back?
  • This update broke my entire experience.  I lost my watch face, the battery drains at a 3x rate. I can’t use connectIQ to fix it as it keeps saying my watch needs to be updated. I’m stuck. Please roll it back
  • Beside resetting my watchface, it also wiped my "OTP Authenticator" App. That means, restoring all my 2-factor authentications from scratch.
    Luckily, I am home; had I been on a business trip, it would have been a major inconvenience.
  • You can add "Various bugs and Deteriorations" to the list above.
    I'm a Connect IQ developer and I have been receiving hundrets of complaints about lost watch faces during the last 3 days. Not funny!
    Garmin, since you are now also selling Connect IQ watch faces you should start caring about those in your firmware updates.
  • The volume control when playing music is now ruined as well. The round indicator does not change position, and the sound does not go above a certain level. In loud places, you can barely hear what is playing.
  • thanks for your work btw
  • here are new issues that appeared after the latest update on my tactix 7:
    - battery drainage (now it kinda 2 days a day)
    - HR sensor was turned off after the update. Expected: HR is turned on as configured
    - start\stop button lights up the display at a 100% level. Expected - 5% as configured
    - turn ON the sleep mode outside the sleep hours, press start stop button - shows a regular watchface, exits the sleep mode. expected: shows a prompt whether to exit the sleep mode or not
    - turn OFF the sleep mode when whithin the sleep hours. Actual: sleep mode activates in a while/ Expected: sleep mode not activating itself if turned off
    - Open Settings - >  Format Actual: All the units and preferences areset to default values. Expected: All values are same as I configured.
    - Long press Menu button - Clocks > Back Button. Actual: The watchface is shown. Expected: The previous menu is shown
    - Long press Menu button - Watch Face > Back Button. Actual: The watchface is shown. Expected: The previous menu is shown
    - I ran 4 km, was running with my wife, she has a venu sq2. Satelites mode is set to All. The watch shows I ran 5 km.
    -  Daily naps are no longer automatically detected. Since 20.22
    - Strobe - Choose Any mode that is not a default one. Turn off the strobe and exit the menu. Open Strobe Again. Actual: A Blink mode is shown. Expected: a mode that i previously used is shown. Since 17.xx or earlier
    - Logs floors climbed when I drive a car. Since 17.xx or earlier
    - you name it
    Garmin, please consider creating a beta for tactix users if you experience lack of QA engineers. OR, please give me my 17.28 and I will stop bothering you and myself. I am with Garmin since the Fenix\Tactix (fenix 1) and what is happening with your software is really sad.
    Please do consider adding an option to rollback software for tactix users.
  • This release is plain comedy!
  • give me my 17.28
    There is a way to do this. Yes, I'm a Tactix user as the name suggests. If you want to give me a holler via PM.
    Some of the issues you mentioned (like battery drain & 100% backlight) might be fixed by factory reset though, At least I didn't saw them with my test system on 21.19 which I factory reset immediately after the update b/o me wanting to have a clean system to test against my production unit on 15.77. But not all of course...
