I would REALLY like Garmin to extend the Race Yourself function, because no other competition has this and it would be an great addition for car racing or other sports where GPS doesn't follow or is not accurate enough.
That is why now we use split times during special stages to know if you are faster or slower compared to first run.
We repeat special stages. First time you determine the spots where you will measure the split times. Second run you do split times on the same spot,
and then compare, but it has to be done manually at full speed in your head, while reading pacenotes, which makes it impossible sometimes.
I propose that RACE YOURSELF would allow you to select not only activities that have valid GPS tracks, but also activities that have split times.
And then it would compare first split from first run with current first split (second split with second split, and so on...), and immediately let you know the difference on the 8 second split time temp screen.
The RACE YOURSELF function is there, all the data is there, just this little comparison, little programming, would make a world of difference for this type of sport.
It would also fantastic if the data of the split times of the compared activity would be available, that way you would be able to use APPBUILDER to make a field and calculate yourself.
I am using Fenix 7Pro, but this would really be a general improvement for all current and future series.
Thank you for considering.
