fenix 7 - downgrade to previous version of 20.22
Since update 20.22, my garmin fenix 7x pro solar stills reboot indefinitely.
How to force the previous firmware version to fix that ?
No other damage on the device.
Top Replies
All Replies
  • Hello
    I am sorry to hear you are having this issue. If the watch is rebooting, I would first recommend trying to powercycle the watch. If you are able, I would also recommend trying to reinstall the software with these steps:
    1. Hold the Menu button
    2. Select System
    3. Select About
    4. Press the Light button roughly 8 times
    5. Select Reinstall software
    if the issue persists, I would recommend trying a factory reset with these steps:
    1. Ensure the watch is powered off.
      • You may need to hold LIGHTfor up to 30 seconds to turn the watch off.
    2. Press and hold BACK and START/STOP.
    3. Press LIGHT to power the watch on while holding these two buttons.
    4. After the first beep release START/STOP.
    5. After the second beep release the remaining button.
  • Downgrade to 17.28 and all Work Fine. No Bugs or Crash
