Fenix 7 Pro on v17.28 - Sporadic sudden increase in battery drain without apparent reason until empty - then back to normal
Hi folks,
TL;DR
I have a Fenix 7X Pro and a Fenix 7 Pro with identical setup and the 7 Pro even having less datafields installed, but the 7 Pro sometimes suddenly starts to drain the battery completely with no apparent reason. How to track down whats causing this?
After a charge cycle, the watch runs fine again with normal battery consumption, sometimes for a few weeks, until the problem occurs again.
I'm running a Fenix 7X Pro Sapphire Solar myself and my girlfriend is running a Fenix 7 Pro Sapphire Solar.
Both watches are configured almost identically, with her watch even having only a subset of the datafields installed that I use. So while I even use a CIQ watchface, she uses a standard Garmin one and I run some glances and datafields more, so she should have less reason for high battery consumption than I have.
Both watches are configured for maximum battery runtime and we do not use the cloud connectivity at all. So no syncing to Garmin, we only track activities on the watch and from time to time copy the files to our computers and import them into a separate offline analysis software. No bluetooth, no WIFI, no auto backup, sleep configured to 2:00 am until 2:01 am because we do not want it to interfere with our usage, no DND.
Datafiels used on my girlfriends watch for your reference:
Heart Rate Zones Chart
https://apps.garmin.com/apps/4885b1e1-7102-4c66-8600-c69f911780d6
Elevation | Grade Chart Pro
https://apps.garmin.com/apps/4cd58e2f-9cf1-4a0f-bfa4-927450b862ef
Battery Graph
https://apps.garmin.com/apps/923cd514-fe15-476c-855e-26846d2007ec
As said, both watches run on firmware 17.28 which is known to run very stable and they are configured identically wich only one accidental difference that I found today, on her watch DND was active for the sleep phase and inactive on mine, but that would have been for 1 minute as we configured it, but yes, that was one difference I found.
While my watch repeatedly runs 8-14 days depending on my usage for GPS tracked activities, my girlfriends watch has the same relative runtimes (relative to the reduced battery size due to being a Fenix 7 and not Fenix 7X size) but SOMETIMES, suddenly the battery drain increases extremely without any apparent reason.
I tried to upload a photo of battery graphy here but it didn't work, will try in a separate post. The graph shows a sudden steep increase of battery consumption and if I draw a line into the diagram, it appears as if it could have started at around 2:00 am which is my only hint, pointing towards something with sleep mode.
Did anyone experience the same and was able to track this down? I don't see any way to identify WHO consumes battery, just that the consumption increases and now since I switched DND off on her watch during this 1 minute sleep interval, we will see if this makes any difference but it could take some weeks to know, since the problem only occurs sporadically.
Thanks and best regards,
Thomas
(Edit: Added info that watch runs fine after the problem appeared and it was charged, until the problem appears again)
Top Replies
  • Hello
    I am sorry to hear you are having this issue. If you are experiencing an increase in battery drain, I would recommend updating the software to the latest SW version, 20.22 using Garmin Express…
All Replies
  • Hello
    I am sorry to hear you are having this issue. If you are experiencing an increase in battery drain, I would recommend updating the software to the latest SW version, 20.22 using Garmin Express. There were some changes to address battery drain, in particular after recording activities. If you continue to experience this with the latest version, our engineers would love to help investigate this further.
    If this is ongoing, please feel to reach out to me via Private Message.
  • Yes!! Same
    I've been pretty stable battery wise on 20.22...charged yesterday midday to 100%...went for a 40min walk and 45min gym and just checked now (approx 24 hours later) and its dropped massively to 58%!! Ihadnt noticed before but its never normally that bad. Was still about 95% after the short walk so it looks like its tanked for some reason! Auto updates are off.
    I charged back to 100% 3 days ago and I'm dropping about 5% a day which is normal. NO activities since.
    I reached out to support who have offered a replacement for £210. It's a good offer - but after a couple of years shouldnt be faulty. Or at least upgrade me to an F8 haha!!
  • No negative experiences for me so far on 20.22. It's performed flawlessly, even on activities which have run longer than 8 hours.
    It almost sounds like you may have left the activity running in the background? (Possible if you hold the back button down and return to the watch face and then never remember to stop the activity).
