I have installed Beta 20.19 and want to get back to 20.16 on my Fenix 7 Pro SS. Please help
I just installed 20.19 because I experienced restarts during long-running activities while using 20.16.
Now, I want to validate whether 20.19 improves the situation. However, I’m generally not a big fan…
The latest public you can revert to is 19.41 according to the firmware available releases in the announcement section. In case you would like to, here is a link: https://forums.garmin.com/beta-program…
I don't know how to downgrade. But would you tell the reason why you want to downgrade?
I'm thinking to upgrade to Beta 20.19 as my F7 Pro always restarts during hike activities
Now, I want to validate whether 20.19 improves the situation. However, I’m generally not a big fan of beta versions. Plus, the ECG feature is disabled in beta releases. That’s why I’d like to have the option to revert to 20.16 at some point.
The latest public you can revert to is 19.41 according to the firmware available releases in the announcement section. In case you would like to, here is a link: https://forums.garmin.com/beta-program/fenix-7-series/f/announcements/400289/beta-version-20-10---check-for-updates-only from there, once connected with a PC via the USB cable, Garmin Express will automatically download 20.16
Please, note, downgrading will return your watch to factory default. To avoid any important settings and stuff, you may create a backup prior the downgrade.
Thanks a lot for the prompt reply. That definitely helps!
