Problem with a Fenix 7X Pro Sapphire Solar to connect to bluetooth, wifi and ant+ on update 18.16
Problem with a Fenix 7X Pro Sapphire Solar on update 18.16: It cannot connect to Bluetooth, is unable to connect to a heart rate monitor, and cannot find any Wi-Fi networks even though I am right next to them. Additionally, the pairing QR code no longer appears. Having another Garmin device, I know this issue is specific to the watch, but I don't understand why. This started happening after a rese
Top Replies
  • Hello
    I am sorry to hear you are having this issue. For this, I would recommend first checking the following:
    • Ensure the watch is up to date to the latest SW version, 19.34 using Garmin Express…
All Replies
  • I even tried Garmin's solutions, like reinstalling Garmin Connect, using airplane mode, and all the other suggestions, but I still don't understand what's wrong
  • Hello
    • Ensure the watch is up to date to the latest SW version, 19.34 using Garmin Express.
    • What is the wireless version listed in the watch menu? Menu, System, About, Scroll down. If the wireless version is showing as 0.00, you will want to try reinstalling the SW version:
    1. Press and hold the middle left button to access the main menu
    2. Scroll to System and select
    3. Scroll to About and select
    4. Press the light/power key 8 times in quick succession
    5. From this menu, scroll to Reinstall SW and select
    • If the wireless version is present, but this is still not pairing, I would recommend using these steps to try pairing again from scratch:
    1. Ensure the phone's OS is on the latest version
    2. Uninstall the Connect Mobile app
    3. Clear the phone cache and history
    4. Ensure the watch does not appear in the phone's Bluetooth menu. If it is, please remove the device
    5. Powercycle the watch and phone. To do this, hold the Light button until this shuts off. Then power on again
    6. Reinstall the Connect Mobile app
    7. Try the pairing again ( Be sure there are no other Bluetooth enabled device nearby)
    If this issue continues, I would also recommend trying a full factory reset with these steps:
    1. Ensure the watch is powered off.
      • You may need to hold LIGHTfor up to 30 seconds to turn the watch off.
    2. Press and hold BACK and START/STOP.
    3. Press LIGHT to power the watch on while holding these two buttons.
    4. After the first beep release START/STOP.
    5. After the second beep release the remaining button.
  • same problem here, i change my Forerunner for a Fenix7s saphirre , i used 2 app to connect my devices ,but now in both apps i cant connect anymore, change enough in a datafield IQapp one of this device can connect , and show data, but another app no. And more strange in my old Forerunner still connect perfect.
    I did all the setups you mention
